blueguy
The Blue One
Do u even know my current mods?? LOL
Catback and cold air? Maybe a colder T-Stat and a PCM? All of that is negated when you put those huge wheels on it though...you do know that right?
mid 16's with 10* timing lol
MSD wires, MSD coil pack, XP Exhaust, K&N Drop in filter, Custom Tune, EGR Delete, TOG Headers, 3inch Downpipe. U bend-delete,
Gotcha, Idid rear that changing the front manifold is recommended due to piston longevity, I am banking on 200K on the motor, I am at 52K. Should the front manifold be changed out for nothing else but preservation? And if I read this coorrect a PLOG on a NA car loses TQ right?
So, bashing aside, if an NA person does not wish to top swap for whatever reason, all the rocker, exhaust, ignition mods, tuning mods, and intake mods are basically a waste of time and money? If the answer is yes that is fine I would rather spend my money on my IROC and see larger gains if that is the case.:th_winking:
hell race gas comes out of a pump............
welllllll since you brought it up, I am going from the inside out, very mild engine build coming this summer, I am not sure what heads I want yet. I like low end torque more than I do top end. I am considering Vortec's with the matching manifold of course. Runners and tb will be absolutely last if I have the cash sometime later due to minimum gains on volumetric efficiency. I don't want to go wild tuning a chip so i will not do anything requiring new injectors, expecially since I just changed them out for updated matched ones. Then I will move to the exhaust. Alot of folks don't like the Edelbrock Titechs but I had some on an 86 305 TPI with a 3" Hooker catback, it sounded great and I noticed a nice top end difference, not to mention I went from minimum shift flare to quit more after the swap (failed part dyno). Then I will get after the suspension, I already have a nice trans with kevlar, transgo stage 1 and vette servo's so I am good for now, and I digress, my bad, I am mainly an F-body guy. Had alot of them. The GT is my daddy car to get my son around. I would just like to make it a lil' better....![]()
12's on pump gas?
Never seen that before...
Yea the guy works for Milzy Motorsports if anyone heard of them b4?? But yeah he had all kinds of stuff. GEN V blower, Stage 3 Heads, Nrorthstar Throttle Body, TOG Headers, Cam, SLP Catback An a bunch of other mods. Those jus the mods i can remember off the top of my head..
The msd wires an coils i couldnt tell if they made a difference or not becuase i got a tune at the same time but i did notice a nice difference. When i start it up an my shifts. But the headers an downpipe install... BIG BIG difference car has a nice idle an louder when gas is applied. An when i step on it it moves much much better than before at slow rolls an high rolls. I would say im jus about neck an neck with stock gtp power now judging from when i drove my friends gtx my power is about equal. Motor mounts an fenderwell intake in this weekend so im sure ill give a gtp a run for its money then lol.
