I think it bases it off what the computer tells it for the torque values. Do you have a stall converter in your car?
its a GT with headers and a short ram with stock tune. :th_biggrin2:
Not a thing else is "modded" on it.
"I think it bases it off what the computer tells it for the torque values. Do you have a stall converter in your car?"
All torque converters have a stall speed and the ECM knows nothing about the amount of torque the engine is producing.
I'm pretty sure the way it controls power is completely based on things that have been pre-measured and programed in as I do not see any way for the ECM to measure torque in the vehicle unless it can as bios said "guess" it based on how fast the rpm climbs vs what gear the vehicle is in.
What I am also assuming is the newer systems do not retard timing but simply close the throttlebody on shifts? Would seem a far better way then retarding the timing.
GeosGP : interesting. I suppose it does make sense now that you explained it. And like you said, accuracy doesn't matter that much as long as it gives you an idea of whether you made it worse or better the actual number doesn't really matter.
Ok and?You sure do know how to talk...or have a fast car...but typing is another thing.
