Offset of Stratus rims?
59VetteFI
I've been searching the internet and not having any luck. Trying to find out how close the offset on a Dodge Stratus is to my 04 CompG. I have a chance to buy some nice 18" x 8" Volk GT-C that were on a Stratus, bolt pattern in 5 x 114.3, but the current owner doesn't know the offset and they are quite a distance away to go "try them on" . Thanks for any help you can give me.
I think I'll tell him to look at the rim. But I was checking into other Stratus aftermarket rims and the offet seems to be in the +40 range, so I think they will work. They need some cleaning up, but I think they will look sharp.
So how much offset can I live with on a 18" x 8" rim? I figure they won't be a good fit if they go under +40 offset.
That's good to know, I think the rims look sharp, I may just have to drive over there with some cash if he doesn't get back to me and check them out the offset myself.
with that wheel width (assuming you are going to run 245 width series tires) you should be able to go down to about +30mm before you start rubbing. i would stay on the safe side of this and go a little higher.
