Abs/tcs problem
L KELLS
On. Here's the problem. I. Have a tcs light on on the dic bur the abs light s off. The system do it self test when the key is turned but about a minute or so the tcs light pops on and stays on until I turn off the car. And ideas
bad wheel bearing sensors...
Do a google search, this has been talked about tons of times.
There's a guide in the "How To" section on replacing the hub.
there is a fuse under the hood for the abs/tcs on the same fuse....check it.....when i remove mine it'll do a hellacious burnout!
