stop contradicting me, i have not said one false statement in this thread. you are trying to talk down to me like im an idiot. i know how these cars react with meth and what is the best route, i DID IT.
i played with my system plenty and i loved running 100% methanol all the time. i never ran it at low boost levels that i would hit in normal traffic because it was a waste. i never got around to running a big setup with a pre and post nozzle setup, which is BEST for all applications with a blown car. if you say anything about that is wrong then you can take a hike.
Ask them not me.
Rodney
The GM uses a "coldwire" MAF system (produced by AC Delco) where the inductance of a tiny sensor changes with the air mass flow over that sensor. The sensor is part of an oscillator circuit whose oscillation frequency changes with sensor inductance; hence the frequency is related to the amount of air (cubic feet per minute) passing over the unit. This oscillating electrical signal is then fed to the car's ECU. These MAF units (such as the one pictured) have 3 pins, denoted +, - and F. F carries the square-wave frequency between - and F. They are powered by +5 VDC from the ECU's regulated power supply.
you are a retard, and your tune sucks.
Really. GM mass air meters don't send a 0-5 volt signal back to the computer? Then how do they work? And why have I used this signal to work with our controllers countless times? Also, how is it I have had customers use the LS1 mass air on their 3800 engine by using a 3 to 5 pin adapter pigtail?
Rodney
Your not only giving our customers wrong information your on our forum. How do you not know how a GM MAF sensor works vs a MAP sensor is beyond me.use a "coldwire" MAF system (produced by AC Delco) where the inductance of a tiny sensor changes with the air mass flow over that sensor. The sensor is part of an oscillator circuit whose oscillation frequency changes with sensor inductance; hence the frequency is related to the amount of air (cubic feet per minute) passing over the unit. This oscillating electrical signal is then fed to the car's ECU. These MAF units (such as the one pictured) have 3 pins, denoted +, - and F. F carries the square-wave frequency between - and F. They are powered by +5 VDC from the ECU's regulated power supply.
Your a idiot, You do know Chance started and runs this forum right? :th_jester:
Why do you think we commented on the nerve of you to get on here. Duh!:th_lightbulb:
Real classy answer, Your true side is showing again.
By the way Rodney how about you learn how a GM MAF works before giving people advise. They output Frequency not voltage. Very scary you don't know that. You guys should stick with the Grand Prix experts that are the actual vendors on the site.
I just want to point out so someone does not try this. never hook up an item intended for 0-5v input to an item that gives off a 12v signal ..... Anything that is gm maff is this way. But you should not that because like you said you have sold hundreds of these.
You said that theirs was not progressive which it is. So why not ask you?
you done nothing to benefit this site so your not wanted here.
