copgtp
Your ClubGP Liason
So I'm looking to buy a set of ported heads off of another community member. Everything that is done to the heads I understand, except one thing, here is the quote from him:
"They were milled 0.015 which with the 0.052 headgaskets caused a decrease of 0.025 and increased the compression 0.5 to 9.0:1 on the GTP (factory 8.5:1)
(i think that math is right, i know whatever it is.. it comes out to a 9.0:1 ratio)
Of course you could always run the stock thickness or even thicker than stock gaskets to decrease the raise in compression, but it ran good with the extra bump. "
So am I going to run into any problems running this setup??? An increased compression ratio certainly going to effect some things right????
