DIC flashing zero
matt5112
Installed an overkill PCM and now my DIC is flashing zero on all settings and the trac off light is stuck on (I.e. trac button doesn't do anything).
I've checked the connection to the PCM, all fine, no bent pins etc.
Any thoughts?
bricks are tasty. I'm going to put the old one back in to see if it will work. If it does... PCM must be at fault.
