300+ hp?
HV3 is only for the N/A aplications, it doesnt do crap when your car is boosted.
Im keeping my car N/A and so far have powerlog and downpipe on the wishlist. HV3 after that and MAYBE a camshaft. Im really mechanicly stupid so Im getting difficulty of instalation into consideration, since cam and rockers Id bring to the shop.
If i was going turbo id personally go with Cartuning Performance Turbo kit, 350hp to the crank bone stock. With the downpipe. But its pricey, maybe even a bit overpricey (4000 with the IC!)
Oh okay. I see. Thanks!
Yea, I'm looking at both the Z3 and the Cartuning Performance kit. They both look nice.
Indeed they do, although Ive never liked the sound... Whipple SC would be my dream but its an even bigger money pit.
Hmmm... Haven't heard of them. I'll most likely go with the CT kit, simply because I live in Canada. But then again, I hear the Z3 is a lot better! We'll see I guess.
Do you guys recommend replacing any of the stock engine internals as well? I've read the 3800 engines are fairly strong, but what should be upgraded when installing a turbo kit? Valve springs, pistons etc.?
the block is good to go for like 800 hp. just leave that thing alone.
the valvetrain is dependent on the mileage and the mods youd like to run.
Sounds good. I have 200,000 km on the car. What upgrades to the valvetrain would you suggest? I'm wanting to hit 400+ HP.
By the way Bio248, thank you so much for all the help you've been giving me. I really appreciate it man.
Well if youre going that high with power and torque, think about getting a tranny rebuilt from TEP...
valvetrain mods depend on the cam or rocker ratio youre going to run. pick those and then we can tell you what you need to run.
Ugh. I ordered a new stock replacement fuel pump assembly from W Body Store, because my fuel gauge is out of whack. However, I just realized... Won't I need a stronger pump when I decide to go turbo? Or is there a re-wire kit I can use that will suffice? I heard the Racetronix one won't work for 2001+ GP's. :(
the stock pump is usually pretty good unless youre going for an all out build.
why wont the racetronix setup work?
Oh and Bio, I think I'll go with the ZZP ST2 cam. What other valvetrain upgrades would you recommend to prevent me from blowing my engine to **** with a turbo? Lol. Remember, my car has 200,000 km. Thanks again bro.
I'm curious to see how this all works out for you because I have the exact same car and am stuck between the Z3 & Z7 kit with IC. Looking for a DD car, just want to pick up more power and be a lot of fun to drive but still be dependable. I am only looking to get to about 300 hp, so I was stepping up to the #42 injectors but was also told the same thing about the fuel pumps in the 01 GP's? Was told the rewire won't work and will need a new fuel pump, but have had difficulty in anyone telling me what pump I need? I'm in the same boat as you in regards to the fuel sending unit being bad, I never know how much fuel I have becuase the needle is all over the place. So I figure if I'm going to change the sending unit might as well get the new fuel pump installed at the same time, anyone have info on what I should drop in my tank for this type of set-up?
i dont know the specs on that cam, does the site give recommendations as to which valve springs to run? youll need beefier ones than stock, thats for sure.
a Z3 kit is going to put you over 300hp for sure. turbos are no joke on these cars when setup right. the racetronix setup you get from PRJ is the best fuel pump solution on the market.
Yes, they recommend 130# lb valve springs. So is that all I need? Do I need valve spring retainers or anything?
When I emailed ZZP, they recommended the Z3 kit over the Z7. Yet, everyone here is recommending the Z7 kit. I'm undecided again.
