Bedwards
you will have to have the pcm tuned for the new trans settings...also dont forget about the headers. You will need to get the extra air out before you put more air into it. So if you do everything all at once, it wont matter as you need to get it tuned anyway. I assume that you need a FMHE as well as pump for it, and all the gaskets and new fluids as well. Personally I would get the lower mileage trans if you cant afford to get one from TEP. and while the trans is out put a new filter on it before you install it. You may want to consider get the blower ported before you put it on there. This will improve flow, lower knock, and lower the temps which will all help you have a faster car in the end and make it easier to tune. Since you are running an IC you should port both the SC and the LIM for improved results.
I keep changing my mind on what I want to do. I think I've gone back to the idea of changing the rockers/headers, instead of the cam. After researching it further, I can't afford it (with everything I wanted to do). So I have the headers aspect covered. I'm confused with what you mean by getting a new FMHE, pump, gaskets etc. Why will I need these? Sorry, I'm kinda new to this stuff.
just buy the diff from an HD trans and swap that in. you want the 3.29 gears from the non-hd trans.
My current transmission has 200,000 km on it. Will it withstand the extra power with just replacing the current differential with the HD differential? What beneift is the 3.29 giving me? Wouldn't it be better to just buy an HD transmission with 1/4 of the kilometers that mine has?
