which gasoline brand is better?
Zainoman
I usually go to quiktrip but i thought about using Shell. is there really a difference or am i wasting my money?
Shell here in St. Louis, their Premium is 93 octane. The QT's here only have 91 octane as their premium. I almost always perfer Shell gas over most others.
Anymore, one is not noticable better than another. Just go for a higher octane and you should be good.
Amoco and Sunoco rated top in quality last I saw. BP stations have had issues with moisture in the gas. I use Sunoco since it comes from American oil not Saudi mid east oil.
Sunoco uses a lot of ethanol to raise the octane of their gas. I always got 30-40 miles less per tank with it. I use Hess locally since there isn't a Shell on my way anywhere.
Im not normally choosy, but prefer Amoco, Sunoco, Marathon when we go out of town. Here we have Sunoco in 94 octane so thats what the play cars get for the track or the weekends. BPs around here have all swithced to Amoco fuels as they were bought out by them, but BP a few years back and earlier seemed to have the most problems. A few times they even accidently put diesel in the 87 tank in the ground!!!! Needless to say a few people got new engines out of it!
I found that if I add a little bit of water, I can go further on less money.
haha
I go to Shell or Conoco. We don't have any other big stations. The rest are the cheap kind.
Im curious as to how you came to this determination?
When I had my T/A I ran 94 in it. Sunoco was the only station with it at the time. I use to get quality reports on the rankings of all the major chains and where they got their crude from for refining. My ex's mother worked in an ofiice for a refinery. Thats how I found out about all the quality issues with BP. That was well before it was on the news. Plus BP had a recent scam where debt numbers were being stolen from their pay at the pump machines. So I avoid them. Too much negative news for me to trust them.
As for the gas mileage with sunoco, I dont see a drop with using the sunoco gas.
A lot of stations are doing this to save costs. they are suppose to post the % on the pump. I have noticed lately here almost everyone has ethanol % stickers on the pumps.
94 with ethanol would still yield better performance, the 10% alcohol (although not a lot) helps absorb a bit of heat from your air/fuel mixture, and cooler air in result gives you increased volumetric efficiency etc etc......
Found this info on a different site
It may sound weird, but I get better gas mileage with shell..... I've tested several times, and I seem to get 1 or 2mpgs better
Shell. I used to goto speedway but I was getting around 2* of knock with a stock pulley with their premium. (92) Now I get Shell 93 and get no knock unless its super cold out and I got WOT.
