Dogbones
CTKGP09
i was looking online and i came across the zzp shorter dog bones...and then i came acorss the solid motor mounts. i was wondering if either of these would b a good investment? would either help out performance considerably?
btw i have factory suspension and factory motor mounts and im installing my zzp 3 inch downpipe in 2 days so consider that too please
Solid motor mounts are worthless. I had one from ZZP and it squashed in less than a year. Get yourself a regular fluid filled one, drain the fluid out, and get yourself some mix your own poly-urethane and make a poly mount. I can link you to a writeup that I did. PM me if you want it.
dont get shortened dog bones unless you have dropped your car. The mounts are really up to you...are yours shot?
no the r still good i was just wondering if there is any advantage over stock but im goin to have stock suspension until i move outta pittsburgh ha
It is all a preference of how you want your car to feel. If you go with solids, you will get more vibration, etc. than if you stick with the stockers. The response gains are there, but minimal. If yours are OK, I would stick with the stockers. There are better mods to spend money on if yours are OK.
And don't do this either...
You can go to Auto Zone and buy solid rubber ones for cheap. Just ask for them.
