pictures for every1 of GTP
just because i can...
cleaned it up well?? but yeah tomarrow night were going to finishs "long story short" i want me and my dad to be together when we do it" idk ive always wanted me and dad to build something which we did for a bad reason lol. but yeah i get off at 3 tomarrow around 5 she will be alive again =]
me 2 minus the ears and green hair LOL but yeah UPDATE we started her up[ she ran better then ive ever heard it run before 20 minutes in it starts knocking......... we take the pan off today to discover 1 of the oil filler tubes bolts had the top of the bolts head sheared off were thinking the piston was hitting it becuase now theres a nice guouge in the oil pickup tubes neck..... hoping to have it done in 2 days tops ..... ughhh
Keep us posted!!
Almost have mine out...she's all unbolted (I think) just won't separate from the trans, I *think* everything is unbolted. :confused:
Keep us posted!!
Did you get the "bee-yatch" bolt out?? The one that runs in from the passenger side?? It takes like 2-3 ft of extensions to get at it from the passenger wheel well...
Yep, got that one out last night before I called it quits. I can't think of anything else that I missed.
All I can think of is the bracing bracket that runs to the side of the engine block.
2 bolts on the trans diff cover, and 2 (13mm??) bolts to the engine block. I missed the 2nd bolt to the block for a few minutes...
That bracket has to come out to access the rear bellhousing bolt. There are two on the top, one on 2 on the front side of the bellhousing. Sometimes it can be tricky to pop the tranny away from the engine as the dowels hold it in place.
