well i can basically drive around all day ripping around and my trans temps stay around the 150-180 range all day, even in 100* weather. Before my temps would get to 200* within 15-20 minutes of really light driving, by the time i get to the highway to open it up, my trans would get to 210* :th_nervous:.
The only thing is, in the morning i have to let it warm up longer so tcc will lock. It just takes a bit longer to get to 80*, rather than before.
I had a leak but, i easily fixed it. The directions said it might leak within the first 100 miles or so. Just keep an eye on it. It leaks where the fittings are on the tranny cooler itself.
Another note, im not sure how you fmhe guys would go about mounting this one. I guess ill have to figure it out too, down the road.
so what did you have to do to fix the leaks........did you just snug up the AN fittings on the cooler or ?
The TCC will not lock up until the tranny fluid is around 100*F, so keep this in mind in the winter time. I cover my tranny cooler in the winter time just for this reason.
you dont have much of a "winter" compared to us........I had my Desert Fox installed in January of this year when my tranny took a dump, I didnt seem to notice an issue with the TCC on mine? Are you talking about severe cold weather conditions? Or just your average winter temps?
And just how did you cover your cooler?
Tcc will lock at 80* according to trannyman. I usually let it warm up till about 80-82*, before i start driving.
