about the keys for a grand prix
thenervemann
Okay when i bought my 98 grand prix 3.8l i recieved four of the same key that i use only for the ignition. they do not work for the trunk i was wondering is there a seprate key for the trunk i need to have made or does the ignition key always work and there for mine must be broken. i hate having to use the button in the glove compartment its annoying sometimes.
if you can spend the $135 and get the keyfob from the dealer, thats what i did, mine didnt come with a fob and i cant live without a remote button, im just too lazy
You can get Keyfobs for cheap on ebay or from moradpartscompany.com.
Actually, I have a spare one for my 2002 GTP, lemme know if you want to try that route.
I have had to program two keyfobs for my 98 gtp......I bought new OEM key fobs on ebay(about $25 each shipped.) You have to program each one......it is about six or seven steps. It literally takes about two or three minutes for the entire process. You have to pull a specific fuse and go through a couple of different steps........not to bad. I would fully recommend it. When I bought mine it did not come with a trunk key release(it was shaved and I see the metal plate that was welded in on the inside of the trunk) so I did not have a choice.
Hey! Do we have a writup anywhere on what the process is to reprogram those keyfobs??? I got one with my 98GTP but its not working, even after a new batt. Thanks!
I dont know if it is on here or not..........PM me if you need it and I can do a write up on here for it if needed.
there is another way to do it with out having to pull fuses. but i cant remeber it off the top of my head right now. i will try and find it and get back to you with it
You should be able to press lock and unlock at same time until the horn sounds, then it should be synced again.
