Squeaking
BwolfGT
There's a loud and consistent squeaking noise coming form my front passenger wheel whenever I drive, any ideas?
i was thinking wheel bearing... but it shouldnt squeak... it could be bushings in suspension/sway bar ...etc.
by consistent do you mean non-stop while driving, or does it come and go while you are driving, but it still takes place every time that you drive?
Its usually non-stop while driving except when I brake...but then the breaks squeal :p
Sometimes it goes away but not often
I would lean towards the wheel bearing. If it is the sway bar it should only make noise where it is bumpy or when turning. I assume it makes noise on a smooth road as well? At all speeds? does it change pitch with speed?
struts or supports? I dont know though............if that is what it is I would think it would only be this way for bumps and turning as well.......not all the time.....but who knows, there have been stranger things happen.
Yeah. I think I'm just gunna slowly replace the whole suspension, high miles its all bound to go at some point anyway
I have the same problem but mine stops squeaking when i turn right, i think, but its a constant squeak, and its very annoying, i've changed my rotors and pads, but it still there. i hope its not the cv joint.
