that vid and a cobra vid are what helped me convince eric to buy his 2300ax for the Riviera, that sound is addicting, and yes we'll be keeping the WAI just fer that reason lol
this is just a 3/4 throttle romp...cant wait to ditch the 3.8 and put the 3.0 on...
Eric's WhippledRiv is getting some new toys fer 08
IS3 heads (manley valves) machined for foggers in the port floor
IS3 cam (will be going to a custom solid roller grind after 08)
stripped 05 L32 block ready for lots of work (step drilled main galley, drilled #2&3 mains, valley drainback holes plugged/stovepiped, external wet sump pan with baffles, crank scraper & full length windage screen, relieved bores)
jp dbl roller
intense mps for the new larger mech ic pump/snout support/beltwrap system
3.25 & 3.0 for the whipple (baby steps lol)
TCI balancer
150lbhr injectors (got E85?)
AEM low imp injector driver
2 stage direct port fogger w/ purge, gauges and spare bottle
SDD -10 fuel logs with L32 pulsation dampners
Weldon 2035 Fuel pump (1600hp gas & 900hp ethanol/e85)
Aeromotive adj fpr
-12 an stainless sump to filter to pump, -10 to Y, -10 to rails, with -8 returns
90mm FAST billet TB
SDD 120mm billet 99+ L67 maf housing
5" tube WAI
thats most of it, he needs to start gathering other parts. 4t80e, struts, hubs, balljoints, and other maint items for a 160k chassis heheh
