This thread is so lame LOL Can you not search a website to find a part...or use Google? Just wondering...it isn't hard. Because when you google, "Front Powerlog"...look at the first thing that comes up... Google And before you ask...no, you don't need the rear manifold OR the crossover.
Case Learn:
Just go to any dealership (or anyone else with a Tech II or Snap-On scanner). Ask them to perform the Crankshaft Position Variation Learn program. If they aren't sure what that is, tell to them to get the book out and figure out how to run "DTC 1336 - Crankshaft Position (CKP) System Variation Not Learned". It only takes a couple minutes. Be sure to tell them to "NOT REFLASH the PCM". If they reflash it instead of doing the CASE learn then you have a stock PCM again...YAY! Much more KR. Intense should do one free re-tune if a dealership does overwrite your tuned PCM.
