any vacuum line..since there is only one..
(the one that goes BBV > FPR > LIM > MAP)
So, cutting the stock vac line between the MAP sensor and the LIM is the best place? I was thinking of maybe switching out the 90* rubber connector that goes to the MAP with a T and running the line to the gauge that way. I just bought a new vac line assembly when I done the LIM gaskets and I would rather not cut into it. If my idea would not work, than just get a rubber T and cut the line and put it inline and run a plastic vac line to the gauge?
Did you run a hard plastic line for the boost gauge?
