Boost gauge...
So, cutting the stock vac line between the MAP sensor and the LIM is the best place? I was thinking of maybe switching out the 90* rubber connector that goes to the MAP with a T and running the line to the gauge that way. I just bought a new vac line assembly when I done the LIM gaskets and I would rather not cut into it. If my idea would not work, than just get a rubber T and cut the line and put it inline and run a plastic vac line to the gauge?
any place is good most people like it there because it is hidden out of sight, i hooked mine up last night and just ran a T and took of that 90 that you are talking about and i haven't had any problems yet
i put an extra T fitting on the MAP sensor input and continued the line into my car. realistically you can do it anywhere. i ran a soft rubber line and it works just fine.
