Offset and Backspacing?
here, ill copy what i wrote in the chat window:
offset is backspacing. the lower the offset, the closer the wheel will be to the edge of the fender. the lowest you can go without rubbing issues is ~28mm ish. a good offset for our cars is in the +40mm range.
thanks a lot man. you are the wheel god
