Would you have to change cams at all or leave the stock one in also what about the tranny's. I've read a few post and I don't think nobody really ask these questions. I'm going to be in the process of a swap in the next few months and would really like to know now before I find out that I should have done these then instead later on when somthing blows in my face and feel like idiot.
do you need a new map sensor for a top swap or will mine work?
you need the 2 bar L67 map sensor for it to work correctly. it wont be able to read boost without it.
ok, so then will any SC map sensor from 97+ work? or just series 2?
i would stick with the series 2 just to make sure it would work.
I got a 98 and ill be top swapping in a week!!!!!!!!!!!!!!!! wooooo
Nice, I have 98 L67 parts on my 02![]()
and can it be as easy as going to a salvage yard and getting like a crashed gtp and swapping over the necessary parts?!?
You could use the GTP PCM but it would need your VIN programmed into it.
and mine is an 03 so they didnt make em supercharged yetbut are the parts form an 04-05 compatible to my 03?
