penright
I had a road construction incident that almost knocked off my driver side, rear door, lower trim. It was being held on with the rubber seal and back screw. It was knocked off all the white clips. After pulling it off, other than some missing part on the very bottom, it does not look too bad. You can not see the missing chunk from the side of the car. I am guessing there is no way to find a matching part. I just going to reattach it. I may or may not reinforce it with fiberglass.
I need help to identify and source the two clips. One that hold the rubber seal and the other that holds the trim.
