Fivefingerdeathpunch
Very nice, now do a wheelie!!!!!!!!!!!
had the massive 16inch 2600cfm flexalite fan die recently. it was over 4inches tall and really close to the manifold....however since the car will probably never get the ac compressor put back on i got a thin fan 1600cfm summit brand. nearly 1 1/4inches more clearance...also put some of that sweet gold heat blanket from DEI over the fan motors to help reflect the IR heat at least.
also had the in tank 255 pump die....the turbine style bosch 044 inline pump still managed to produce fuel pressure drawing through a seized gearotor 255
tossed min a good pump and i may unplug the 044 since its running on the 9psi spring till it gets an 80e and we sell the GMR unicorns horn, queef, and converter i guess.
been driving the snot outta it. pretty reliable when you keep it below 27psi.
dear god though chicago streets have me wanting to put on 17's with huge sidewalls or at least replace the GR2 strut bodys with one of the pairs of front agx/zzp coilovers on ****ing MAX, from the twin engine 442 project (before we went to custom knuckles and SLA suspension).
then id have to swap over all the QA1 coiolover stuff with my custom hats/bearings/slack spring etc....and sell a brand new zzp coilover setup with an old GR2 as its core....which means i might as well put the gxp front and rear stuff on the hubs...
...this gonna snowball fer sure.
i recently scrapped 6 gen3 blowers and like 16 cylinder heads.... i kept all the minty cores rofl. so as a w body owner, you can slim down parts stockpiles somewhat, eventually....with great dificulty.
im such a hoarder
