Hurricane87
Is there anything at my DIY level I can do to actually diagnose this? I don't have a fuel pressure gauge, the desire to buy one, or the knowledge to use a borrowed one.
Fuel pressure isn't the only reason for that code.
The V8 still uses only two o2 sensors so it could be a lean problem on either bank of the engine.
Meaning it could be a vacuum leak from a line, a bad intake gasket, throttle body gasket, intake tube issue or exhaust leak before the o2 sensor.
A live data scanner would let you watch fuel trims, then you could go around with brake cleaner or something to watch for a change in the trims.
Past that you really need a smoke/fog machine to check for leaks or rent/buy a fuel pressure tester to make sure fuel pressure is within spec. Sometimes you have to pay to fix stuff.........
Everything I first typed out is in english, it's not my fault you don't understand what I am saying. Car repair and the lingo behind it is learned and I am not here to teach you this stuff. It's one reason shops and some mechanics make a lot of money.
Yeah I'm sure it's sounds like I'm being a dink here but if you had to ask those questions after my first post, you are better off just having someone else fix your cars for you. Unless you buckle up, research the **** out of your issue and educate yourself on how this code or other problem jive together. Even just using other forums/google etc etc to research possible cause for this code, they would have come up with super similar answers to what was already said.
Big thing you need to learn, no one is getting paid to help you. So stop acting like you DESERVE help. Be kind, be thankful and enjoy the adventure of fixing your own ****. Otherwise gtfo and throw money at a mechanic that probably doesn't give two ****s about your car.
**** off dude. Yeah, i'm sick of your **** and i'm gonna say what everyone else is probably thinking. FFDP was a bigger man than me by kindly educating you even after you came back with an attitude. Look, no...no one knows everything. Thing is, you have acted like you do since you joined here, and people are annoyed by your cocky attitude. You say you wanna "make friends", yet you chastise people for not answering your questions the way YOU think they should. I basically know jack about engines before I joined this forum and asked for help. If it wasn't for the folks here, I'd still be trying to figure out misfires and leaks and how to tune and how to install a cam, etc etc. BUT, I didn't get all my information here. I researched the crap out of terminology, diagnostics, tuning etc on MANY different sites. It's out there.
this is same dude thats too cheap to spring for the $$ to get a carfax on a denali and asks people here to do it for him on their dime.
to answer the question- no. you need to pay a mechanic and probably for any future questions the answer will be take it to a shop.
Is this serious or just being silly? His post WAS english and very basic at that. May I suggest that REGARDLESS of what the issue is or the code is just take it to a mechanic. You have no business opening your hood at this point..... and what I shouldn't have to spend it on is translating your post into English.
I asked NO ONE to "pay for a Carfax" for me, I asked for ways to figure out around the $15 (NOT $5). Someone else gave it to me, I did it, it worked, I thanked them. That's how it should work.
Despite the president we have, lies don't really help your argument. And if $15 is a trivial amount of money to you, why are you here?
