My 1984 K10 - LM7 swap!!
Waiting on transmission parts. Spent some time on the engine... IT RUNS AGAIN!!
I guess I start pulling the K10 apart now?
Cammed engine on a stand, that is HILARIOUS!
My kid thought it was great. lol
Sounds good.. gutsy firing it up like that..
Haha! It was about 4/10 sketch factor. I saw some hillbillies fire one up on a 3 wheel stand that looked like a cooked noodle and wind it up to about 5k without tipping. I felt pretty confident in my setup after that. I think you're safe as long as you put the pin in the pivot.
Keep telling yourself that, I've done a lot of stuff I shouldn't have and merely saying.. you got guts buddy.
PS.. remember that picture of the road I sent you.. still looks like that.
Very nice, sounds GOOD!
I've started many engines on an engine stand before, but never without a cooling system, or at least water in the block.
You can let em run for several minutes without coolant, the oil is still cold and will help keep it cool.
I'd let it idle longer to check for leaks and crap like that while it's on the stand. You can even just shove a garden hose down the water pump neck to keep it cooler longer.
Update:
The Yukon shell is tentatively sold for $500. Guy gave me $100 to hold it, balance to be paid on 10/20. I'm counting my chickens before they hatch here but...
Bought running Yukon for $1000, sold the t-case for $350, some other misc pieces and parts for $150 and the shell for $500. That's a payback of $1000! That makes the motor, transmission and all the other little trinkets I pulled FREE!! Only as far as dollars are concerned though. I worked my butt off to get them out. Still calling that a win.
The 4L60e I was building for a buddy is finally done and should be picked up tomorrow.
This clears my plate to focus on the K10 disassembly. Unfortunately, do to the way vehicles are situated I really can't decommission the K10 until the Yukon is gone. So I guess I spend the next few days planning and researching...
is that a stock rebuild on the 4l60?
Not really. Some performance upgrades but no major hard parts.
Alto red frictions and kolene steels. Trans-go valve body kit and upgraded aluminum 1-2 and forward accumulator pistons.
*Edit: Corvette servo also.
