showtastiik
Shift Kit and sonnax lube tube retainer? The drill didbt damage it though. Anything else I should look into while I have it out?Oh ok! I thought this was the one in your car! Lol
I'd bet there's a hole in the trans pan right under here where they drill to release fluid. This is the 1-2 accumulator. If the damage is just the drill, you can swap your old one in no problem.
I'd look into doing a shift kit while you're there and I'm a fan of sonnax lube tube retainer while the pan's off.
If it isn't damage by the drill, I wouldn't touch this transmission unless you're doing a rebuild.
Also, just checking, this isn't the comp-g one we told you wouldn't work is it?
Sent from my SM-N950U using Tapatalk
