jetfighterv
So last June I bought an 87 fiero off a buddy for $150. What I thought was gonna be an easy fix turned out to be way worse after replacing so many parts I finally found out it was rod knock. Weird thing was it didn't sound like it at all it sounded like it was conning from the top and when id lay under the car and listen I could barely hear it. So I just last fall pulled the entire cradle and pulled the motor off. I knew that it was never gonna go back in. What came out was a almost ready to die 2.5 Iron duke with 90hp and what's going in is a 240hp 3800sc. I got a hold of a great guy named James and is making my custom wiring harness and programmed pcm for the swap. Another guy nicknamed Fierorog is gonna be making my custom motor/trans mounts, custom flywheel and alternator relocation/pwr steering delete bracket. The 3800 is going to be mated to a 5 speed F23 trans out of a 2001 Cavalier. My donor car for this project is a 2001 Pontiac grand prix gtp that I picked up for $350 because the owner lost the keys. Now thanks to a lot of guys on here the car is running great and I will be driving it to work and school till I can buy everything I need for this swap
