Shyt. I couldn't wait. Wasn't dressed for car work. Was out signing up my son for Saturday Polish school. He wasn't too happy about school on Sat.
She didn't start tho. First thing I did was check the schrader for pressure seeing if anything changed overnight. Again, it was bursting. Checked unions on the fuel lines for leaks, no leaks. Turned the key almost ON, this time I could definitely hear the pump priming.
The code for the MAP sensor was because I left it unplugged after fixing the vacuum line connection. DOH!! Plugged in now, but didn't help in getting it started
Anyway, pulled plug 5 and 3. Both dry. Plugs are copper, Mastercraft, with 1000 miles on them. Known to be good.
To prime the engine yesterday, I pulled the wires off the ICM. I could see the coils sparking. Coils are pretty new, known good. The way it just cranks and cranks makes me think of an igntion issue. In the "My Ride" thread about this car, I posted (back in April I think) pictures of cracks in the insulation on the wires from the ICM harness. Despite the cracks, and green copper showing, I left it on. It was Known Good despite the cracks. Since then, I purchased a gently used ICM harness from a member on here, HighOctaneRacing. Looks to be in great condition. Maybe that's the problem, bad wires leading to ICM?
Is it worth checking the pressure at the schrader valve despite it bursting? Or can we call fuel pressure as being good? Thanks guys.
