My '97 grand prix was due to get a brake job, the pads are down to 2mm in front and 3mm in back.
Today, I was getting a noise from one of the front wheels, sounds like a howling noise, and that seems to imply that is the wheel bearings going bad.
It seems that the easiest way to diagnose which wheel, and if it is the wheel bearings is, to jack up the car on one side, block the other tire, and set the parking brake, and finally, start the car and let that wheel spin. If the noise is there, then it is that wheel. If not, do the same to the other side.
At least that is the plan. Only hiccup of that plan is, I don't have a floor jack (yet), only the scissor one, and I don't have jack stands (yet), but, I do have 3 ton ramps, each one weighs 65lbs.
Looking under the car, the spot where the jack goes close to the wheel is all bent (called pinchweld?) & rusted. No idea how it got bent, never really used jacks on the car before. It has been on lifts before though, could that have been it?
Anyway, I was thinking of using the 3 ton ramps as a safety measure with some 4x6 wood on top to make sure the car doesn't fall down with the scissors jack.
If it is the wheel bearing, would you guys go with Duralast Wheel Bearing/Hub Assembly, or with MOOG http://www.autozone.com/suspension-...heel-bearing-hub-assembly-frnt/831195_0_22589 ?
For brakes, looking at metal (because of harsh winter weather) http://www.autozone.com/brakes-and-...s/duralast-gold-brake-pads/529527_855548_3773
But, how do I know if the rotors need changing? I would get these http://www.autozone.com/brakes-and-...rotor/duralast-brake-rotor/118053_865038_2708 if they need changing. From what I can see through the spokes, they look smooth still.
I rather shop local, just because it is easier to swap out parts in case they go bad.
Oh, and for what it is worth, I just retired now, which is why I haven't done any work on the car before myself. This will be my first project.
Looking to save $$$ where I can, they tell me this car is only worth $900 these days, not sure I want to pour lots of $$$ into it.
Oh, and I was also told that the 3800 engine has that gasket issue, and it will need to be changed, but that is a $1500 job I think the mechanic said, and he also said it is very common n the 3800 engine.
Any comments on any of the above is appreciated!
