sure you have, its what it comes with from the factory.I've never seen a 1" rad on a gtp.....at least not an l67 gtp...
That's how they come normally since their meant to be fuel tanks but you can customize them however you want I was emailing the guy and he said for 40$ they would weld on 2 3/4 npt bungs in the spot of my choice and that they didn't have to put the 1/8th npt bung in if I didn't want but, I was actually going to have them leave it so I could put a coolant temp sensor which most happen to be 1/8 so its perfect. So happy I have literally spent probably ten hours of my life trying to find the perfect tank.I wouldn't run that because it has 1/8th npt fittings, way too small.
Ok well I didnt know if there was a difference since its an intercooler system and not a regular coolant system. It seems it doesn't really matter wether i get vented or non vented. The intercooler system won't be operating at high pressure to where I need to be cautious about relieving pressure.
Well thank you for your help sir!exactly
Would I need two pumps if I ran an icebox to the trunk?
Sent from my LG-H918 using Tapatalk
youd be surprised just how much room you dont have to work with, thats as low as it can go as its about touching the fmhe.I was going to mount the tank probably a couple inches lower then where yours is mounted
I'm mounting the tank on top of the bumper support and its 4" tallyoud be surprised just how much room you dont have to work with, thats as low as it can go as its about touching the fmhe.
