From the Ebay listing:
DVD 2, High Performance version: This DVD Video Manual includes all of the above steps but the information is adapted and added for the use in a High Performance 4T65E, This video also goes through the step-by-step install process of a valve body shift kit, different chain options, how-to modify the hydraulic apply circuits, different horsepower ratings for different clutch packs, supply more oil to the support bushings, proper clutch pack preparation, how-to modify the drum apply area for a better grip, and has a lot of tips and tricks in order to build a 4T65E transmission to run cooler, shift faster/harder/firmer, reduce shift overlap, increase line pressure rise, get lower a Et for drag racing, and of course handle more torque and horsepower. This DVD is 3 hours long.
DVD 1, Stock Rebuild version: This DVD Video Manual is a Complete Step-By-Step Tear Down, Inspection and a STOCK REBUILD of any 1997 and up 4T65E GM Front wheel drive transmission. This DVD is 2 Hours and 35 minutes long. Not only does it tear down, inspect, and then rebuild a 4T65E but it will teach you how-to rebuild all of the following items: direct clutch, input drum, third gear clutch, input clutch, roller clutch, overdrive clutch, intermediate clutch, all the bands and servo assemblies, duel sprag assembly, all of the seals including how to use a lip seal tool that can be bought here on eBay or from a company like Snap On tools, how-to do a dry clutch pack test for the overdrive clutch drum while it's still out of the transmission (very helpful so if there's a damaged or missing seal or even if there's a crack in the piston you'll be able to find it before putting the transmission back together, saving you time and more importantly money), check ball placement is covered in both the crossover plate and the valve body, all the accumulator assembles, complete front pump rebuild, how-to check the clutch packs for clearance, total unit & finial drive clearances and it tells you what they should be set at, how to inspect all of the critical internal parts with just some emery paper a straight edge and a feeler gauge, and it even gives you ALL of the torque specs that you will need for the 4T65E Transmission.
Either of these DVD videos will make all of the ATSG manuals obsolete because to cover all of the different 4T65E’s that you would normally need several manuals that can cost you a big chunk of change, and still you will not get the visual aid that you have with the DVD. All in all this video with help anyone with an average amount of technical automotive skills to do a complete rebuild with great results while using basic hand tools. They are Region free DVDs and it is in a DVD+R format so they are playable on all quality standard DVD players in ANY country. You will not find this DVD anywhere else. As for picture quality of this DVD if 1 was absolutely horrible, a 5 is a standard VHS tape quality and a 10 was an ultra high quality DVD movie that you would rent from blockbuster, then I would give these an 8.5 which means that is has a very high clearly and you can see everything and just to show you, the image for this auction is a REAL screen shot. Finally, while editing, I was able to reduce and or cut out completely shadows in dark areas, and bright reflections off of shiny parts and can distort the images that other ebay sellers normally leave in, I did this because I feel it sometimes deprives the viewer from important information
_________________________________________________________________
I have DVD #2. In my opinion... This does NOT make the ATSG manual obsolete. However, this DVD plus the ATSG manual will give you about 95% of what you need to know. I'd be willing to fill in the other 5% to whoever bought it.
Did I mention I have all the essential Kent Moore tools for this trans? :th_winking: #rentalprogram
