    TIPS:
WTB: Overkill Camshaft
CompCams grind #3326/3307 HR116+2. I don't think many people ran that cam so you'd be better off ordering a custom cam with the sbc spec.
I've been trying to order it. That grind number apparently no longer exists though and the comp cams rep I've been talking with hasn't been helpful at all. Been working on that discussion for a few weeks now....figured I would check and see if anyone has one kicking around as I'm not sure I'll ever get results with CompCams.
I bought an overkill SBC cam from a local up here in Ontario....the guy said Comp Cams was very hesitant to grind the cam as it was not a grind they came up with. He had to get Will involved to get Comp to grind the cam!
You may have good luck asking Will to chime in with Comp to have it made for you.
Good luck!
PS. I have not ran the motor yet with the cam so I cannot give any first hand experience with it!
Yeah it's probably best to give will a call, if nothing else he might be able to point you in the right direction
You order it direct from Comp Cams, is how I got my Overkill BBC... Unless you are just trying to get it cheap (used).
It is a Comp Cam Lobe design (4x4) and has agressive ramp rates. If you have their catalogue, you'd match up the lobes (3206, 3307) 116lsa, 114icl (HR116+2) is a .316 lift 214/[email protected] duration, 134/141@200 duration
its not a stock item, but give them the specs and they'll grind it...
I've been trying to order it from Comp, but the grind numbers are no good anymore I should have mentioned in my original post.
I gave them specs from the Overkill website, and never heard back from the rep I was working with. Been over a week now.
The only thing they offered to do for me was grind the one 3800 cam they have in their grind database, which I am not interested in, and the rep couldn't understand why, even after I told him it's nowhere near the same cam I'm looking for.
The grind #'s are their lobes, their design, they don't expire...
They don't grind 4x4 lobes?
I would find that hard to believe (not good anymore) and think you are dealing with someone who doesn't know what it is you want... Just my opinion. The "GRIND" is done by machine with the spec punched in... Absolutely ridiculous to be told they can't take a blank L67 cam and grind it to spec! Overkill doesn't mean anything to them and don't mention it, just call, state you want a custom cam for an GM L67/3800 and the Spec's are 3326 intake, 3307 exhaust, 116*lsa with 114*icl (+2) and there is no freakin way they should say, geee, we don't have that any more because they don't, you're making it... It's BS! You call it, they grind it!
Haven't mentioned Overkill once. Just gave them the grind specs from the website.
I agree it's BS, but at this point it's the answer Ive been given. He was going to "look into things again", but that was over a week ago with no response since. I need to see if I can get a different rep. Been talking to the current one for overy a month with no results.
As Bake82 said above, the guy he bought his cam from had to get Will involved to get it ground because comp wasn't real interested in grinding it.
If Bake82 ends up not selling the cam he has, I'll contact Comp again, assuming I don't hear back before then.
As Blake82 said above, the guy he bought his cam from had to get Will involved to get it ground because comp wasn't real interested in grinding it.
If Blake82 ends up not selling the cam he has, I'll contact Comp again, assuming I don't hear back before then.
I'll know this week on my SBC. Should be Wednesday at the latest!
Cool. No rush.
I may end up re-engaging with Comp eventually for the Big Blower Cam anyway. Contemplating changing to that cam on my Regal. Running the Xtreme Energy cam from 3800performance right now.
This was the cam they said they could offer, for anyone wondering: http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1075&sb=2
Haven't heard back since I explained to them that it's not like what I'm looking for at all.
Although that cam is close, it's not Overkill's spec.
compounding that... From Comp Cams current 2016 catalogue... Go to their site, download it yourself!
XTREME 4X4™ HYDRAULIC ROLLERS
Due to the allowances of lower engine speed, these designs are slightly faster than the original Xtreme Energy™ Hydraulic Rollers. Great low and mid-range torque. They are our most aggressive hydraulic roller lobes and run well in street, off-road and four-wheeling.
CAMSHAFT TYPE LOBE # RATED DURATION DURATION IN DEGREES LOBE LIFT TAPPET LIFT @ TDC THEORETICAL VALVE LIFT @ "0" LASH ROCKER ARM RATIO @ .050 @ .200 106° 110° 1.5 1.6 1.7
Xtreme 4x4™
Rated Duration @ .006" Tappet Lift Small Block Journal Journal = S,B,F,R… MI 25.9(12.7/13.2)
3324 259 210 131 .316 .047 .036 .474 .506 .537
3326 263 214 134 .316 .052 .041 .474 .506 .537
3303 265 216 136 .316 .056 .044 .474 .506 .537
3306 269 220 138 .316 .062 .049 .474 .506 .537
3307 273 224 141 .316 .069 .056 .474 .506 .537
3308 279 230 145 .316 .079 .065 .474 .506 .537
3309 283 234 148 .316 .087 .072 .474 .506 .537
You can see, the LOBES are very much available as it is listed in their current catalogue! So again, it's BS, you make the call and escalate it till you get someone who isn't pushing BS your way and order the cam you want. So something isn't right...
I've been curious about this cam. But yeah if the guy is feeding you bs, talk to someone else. I have a custom cam in my GN. Called them told them the specs I wanted, done.
