CHI2000GTP
New fuel lines are partially installed. The easy part is done, which was installing the straight lines under the car. Only thing I had to do was flip the fuel filter bracket so it would be more rear facing. Now, the hard part is getting these pre-bent ones up through the engine cradle, around the sway bar and tie rod. The way it’s looking now, I’m gonna be removing the sway bar and since the rack is leaking like crazy, might take that out as well. It should make the job easier and an opportunity to swap that rack out. Brake lines are next so I will need room for those as well.
Scotty,
In your pic, in the post in the link below, did you loosen both the rear and front of the sub-frame to get it down that low? The rear bolts look completely detached, is that correct? Any other tips? Thanks!
http://www.grandprixforums.net/threads/104131-best-way-to-remove-front-sway-bar
Scotty,
