BrandonHall10
Solving problems
Re: Project LQ4 - V8 S10 - So close to making noise...
It doesn't. I'll probably just run a discreet little tach on the column. Already ran the wire from the PCM. Got a 3 hole pillar pod on order. Aeroforce, wideband, and.... another wideband? Or....
Yeah. I though about pulling the plugs too, but I took one look and said no thanks.
Does that cluster have a tach? If not you should definitely swap it out for one that does.
Takes longer than you think to pump up oil on a motor that was apart. Say 2 minutes of cranking on/off for about 15 second intervals. Starter turns it much slower
