WarStryker13
I break things.
I've got a 04 GT that needs a tranny, and I've miraculously found one (JY, 122k), but to go with the trans, I'm planning a top swap. There's a burnt 02 GTP in the neighboring JY and I'm thinking about using it as the donor. The 02 engine caught fire at some point, but it didn't do too much damage, the plastic didn't burn off so it wasn't a terribly hot fire. None of the sensors are salvageable, heads and valve covers are iffy, the TB is in deplorable condition, and the only other s/c 3800 I can find is a series 1('96 olds). I was originally hoping for a 04+ gtp just to make it so much easier but all the way up in interior Alaska, pickings are really slim. Like, slimmer than Slim Jims kinda slim. With so little in the way of parts, this car is definitely going to be complicated, possibly dangerous, definitely hazardous to your health in the engine bay dept. I'm prepared for some fab work, and lots of soldering. The questions that I still have after reading as many threads as I could find on the matter:
1. Is the harmonic balancer from the L67 a requirement or just a recommended? I know the pulley systems are different, but how different, and is it possible to make it work?
2. ZZP has an adapter for bolting a L67/L36 TB onto a Gen 5/L26 UIM, but I am wondering if it can just be flipped around, or if I need a tap & die set and a block of aluminum.
3. I will be porting EVERYTHING, to include the front and rear manifolds. I'm also thinking of wrapping the manifolds (no idea if that will help with KR, but I'm hoping someone else has at least tried this and has wisdom on the subject), Any other modifications I can make to the stock hardware?
4. I dont have the funds yet to spring for headers, a professionally designed IC, cam & rockers, or anything that would have to be shipped... so most of my mods will probably be home-built or things used in a way for which they were never intended. My question is, What is most important/effective for keeping KR down with a blower? I've already got 1 step colder plugs ready and a CAI, but I know I will need much, much, much more...the prideful heart demands it.
5. If the valve covers are beyond salvage, is there much difference between the two? and if the heads are in similarly deplorable condition, whats my next option? I suppose I could copy ZZP's L36 kit and just drill out the LIM for injectors, but I would need specs and documentation... Unless someone knows who to talk to at ZZP for getting custom/partial kits, because extra parts are not in the budget. But I'm definitely going to replace some gaskets, maybe get rid of a few superfluous systems...
6. I'm planning on a Gen 5 blower as soon as one becomes available, but I have not seen one single 04+ GTP up here as of yet. I keep hoping that somebody just drops one off at one of the JYs...(I've been in all of them so much that they pretty much know me by name by now, and at least two are looking for parts for me just because I've brought people and business with me on multiple occasions) If anyone is up in Alaska and has parts or advice, please hit me up.
7. Is there any easier way to explain the BBV? I've read through three threads and still dont understand how to hook it up so it works with the traction control and wont set engine codes...
and finally...
8. If the PCM desperately needs to be tuned/flashed in order for the car to be driveable, and I can not find a "tuner dude" who knows what he is doing, can someone post links to threads or sites that have decent software and walkthroughs? I only have one PCM, so I can't afford to fvck this one up.
I will be posting pics and updates, along with anything new I figure out as I plow headfirst into dangerous territory.
and finally...
