I'll take a better picture, but there are horizontal lines on the two gears that line up with the bottom of the drain plug. they are kinda faint, but they are there. almost look like small dots.
I'm guessing it's either oxidation or some kind of residue from the oil, but the oil LOOKED normal. Light golden yellow color, extremely viscous...thicker than gear oil, definitely. I simply thought it was mildly interesting, since it's simply a surface mark and doesn't extend onto the teeth of the gears.
water? lol that doesn't sound good.... but I guess since there wasn't a gasket that the aluminum could have shrank just enough during the winter to let the tiniest amount of water into the snout... It has hit -60*F here a few times in the past decade or so.
It's possible, make sure to use the anaerobic sealer when you put it back together. it just looks like it's been sitting for a while. It's also possible the heat caused the seal to be compromised and allowed water or vapor to enter the snout. It looks good so I wouldn't worry about it.
There was no trace of any gasket material or sealant on the snout, just some corrosion in the bolt holes, none on the threads though. lol now I just need to figure out what to do with the lim...
My hand held guesstimation was 35lbs each, I wasn't that far off... I don't know if I want to risk two separated shipments, but I haven't had any issues yet so we shall see. Lol
If they're still in good shape I'll definitely grab them, and try to get the HB off. Lol hopefully the block is seized so I can just use the 36" breaker bar I have instead of trying to get a compressor and air impact out there.
so the JY's gates are chained... lol but there should be new management in a few months. I'll head to the other JY during lunch tomorrow, I know they'll have the parts.
