steelholder
it was the last thing i did before dropping in the combo
i have no clue how to use icm or coils? I made sure the fround was onbefore installing the icmtry using your icm and coils.
also make sure the icm harness ground wire is bolted on. if you took the front valve cover off you took the coil bracket off, that black wire gets bolted to the brackets bolt.
