can you be more specific? not sure what you are asking
Turbocharged400SBC said:That's just a funky dual wastegate setup. Usually when yer wg is undersized for the lower boost settings (high bypass/reducing drive pressure)
I still have a ton of gtu/indy beretta stuff.It seems that this setup is running a turbocharger with a split hotside (divided housing) and according to my source a very large turbine housing and wheel. The engine still uses the stock converter which flashes around 2200-2400rpms. The point is I have not seen anyone running setup like this that pulse the turbine efficiently for a street car. So wanted to hear if anyone has seen a working setup on these engines are what are there thoughts
Actually these are two functional waste gates used to control each bank of the turbine (housing)
It is actually a 88 beretta GTU, with a 3800, not sure what type or version, but I am told it maybe a series3, getting a custom specific camshaft (no one knows much about the car...I am still digging)
Its just a twin scroll turbo I don't get what this "pulsing" is. Evo guys have been using twin scroll turbos for ages.
Obviously since its divided housings you can setup separate waste gates. I still don't see how using different WG pressure would matter. It would vent to whatever the lower pressure is and defeat the purpose of the higher pressure waste gate so both would have to use same pressure WG springs.
Edit. Does look like a fvck ton of fun in a light car! Wonder what it weighs. 2800#s is the goal for my caged gutted GP. Once engine trans and turbo junk is finished.
Y'all are doing it wrong.
Equal length primaries with consistent cross sectional area at the merge into each scroll.
how is this not more complicated then necessary. Need to spool a bigger turbo use a 2 step......
Looks like a lot of work for what?
Just buy right sized good turbo and call it a day....
