MrPoopyButthole
#Billsnamechangessuck
Re: Built 4t65e - Almost done...
Wait a minute...did you buy this pan from me?
LOL! Not unless you have another alias on the GPF. I would definitely remember buying a pan from someone with your current screen name.
I sold it to someone and they probably sold it to you, because that oversized plug is what Bill and I tried but it failed anyways.
Edit...YOU DID! This is my old pan, I sold it to DJNight2k and you bought it from him.
Yeah ZZP sent it to me stripped. I put it on and it leaked. Emailed them and they said "Either I pay to return ship it with a 20% restocking fee and then just buy another from them or I could just live with it." That was the option ZZP gave me.
BTW read my above edit.
now drill the end of the plug for a neo magnet or get a magnet equipped plug.
inspections are quite easy when you can leave the dipstick in, put a shop vac on the case vent, remove the plug and inspect the shavings/accumulation on the magnet and reinstall without loosing a drop of atf.
Want to build mine now lol. I need it bullet proof
Sent from my SM-S820L using Tapatalk
Sticky
How much you have in this all together?
i expected that helicoil to give you a problem with leakage, that will leak overtime as the rubber gasket degrades unfortunately. The only real way to fix that permanently is to use a proper threaded insert, you can pick them up on mcmastercarr. Been down this road before with oil pans.
