    TIPS:
06 L26 Overkill PCM, Pistons, Drag Radials, Cowl Hood
Swiggles
Donating User
Everything ships from 02169. Everything is OBO.
Mickey Thompson Drag Radials mounted on nice drag rims. 15" tires are 26x10-15. These tires are new, never filled as far as I know, bought them from someone and never used them. Wheels are used but in excellent condition. Will get better pics. Tires are over $200 new each. $400 shipped.
Grand am aluminum brakes front and rear. Calipers and brackets included. Probably should be rebuild, they've been sitting. Race use only! These are too light to use on the street. $100 shipped
L67/l36 (3 wire) TAC. Good for you turbo guys ;) . $60 shipped
L67/l36 maf block off brand new. $10 shipped.
Overkill PCM for L26 2006 GP. Base generic tune, egr and 02 delete, might be 180 tstat also, i never got around to installing it and bought it used. $75 shipped
Brand New AC Delco Ignition switch. I know it works for 2000 but i dont know what other years. Part # 26068757. $65 shipped
Remote starter by stellar alarms. Brand New. This alarm uses your factory remote as the starter remote, you just push lock 3 times and it starts the car. The website no longer works but it comes with instructions, model number RS1050. Sold
http://www.amazon.com/gp/product/B0...arms RS1050&qid=1445131289&ref_=sr_1_2&sr=8-2
Custom Cowl Hood. Made from 2 stock metal hoods and is functional. Black $500 OBO LOCAL PICKUP ONLY.
Album with more pics of the hood on the car.
http://s451.photobucket.com/user/Swiggles/library/Hood Pics
Passenger side motor bracket from an l36. You have to drill and tap a hole on the block for it to work on an l67 but when used with the bonnie ICM mount you have more clearance for an Intercooler. $20 shipped.
97-03 GP 3rd Brake Light. Have a couple $15 shipped each
Glove Box button and trunk release button. $10 shipped
Stock Tail Light Harness, with some bulbs. $20 shipped
TYC Fog lights, Pair. Brand New with brackets and bulbs. $40 for the pair shipped.
L32 rods with Federal-Mogul Speed-Pro pistons, one piston is smashed rod is fine. Here's the specs from summit but apparently they don't make these pistons anymore. $100 shipped Throw out an offer plus actual shipping.
http://www.summitracing.com/parts/slp-h871cpa
Hoosier Quick Time Pro Drag Radials mounted to Beret rims. Tire size 26x9.50-16LT 6 passes on them, still look brand new. These are $200 per tire new. $350 shipped
HUD and switch, no harness or dash trim. $35 shipped.
97 Digital DIC, no Trac off button. $20 shipped
I also have coil packs, icms, fuse blocks, various brackets, idle pulleys, tensioners, timing covers, wiring harnesses that I can take connectors from, just tell me what you need and I probably have it.
Vogtland Springs/AGX Struts, K&N Intake, 06 L26 Overkill PCM, Pistons, Cowl Hood
97-03 Dual heated seat bezel with switches. Made by easy performance. $45 shipped
97-03 single heated seat switche bezels $15 shipped for both
Steering wheel buttons, one has a scratch in the paint. $10 shipped
Re: Dual Aeroforce $360 shipped, Pulleys, Roof Rails, Pistons, Cowl Hood, etc
Might be interested in that remote start... may have a pm coming your way
I really wish I got to installing it, seems pretty easy and start forward.
So it's still new?
Edit: It's new, Either you changed it or I can't read. Probably can't read.
You should buy them then :)
Yes the remote start is brand new still in the box. Has been sitting on the shelf in the basement for 6 years lol.
Better pics of hood?
I can take some, what kind of pics are you looking for?
Well, pic is kinda dark, would like view from drivers seat as you provided and maybe a few in daylight, front, sides, back but outside car and under hood. : ) appreciate it... Thanks
$10 shipped on lug covers?
Re: Aeroforce, 8rib pulleys w/ hub, Roof Rails, Pistons, Cowl H...
God damn it Brian!!!!!!!!!!!!!!
Do you seriously have to sell this stuff when I have no money right now????!!!!
I wish you showed me all this stuff when I was at your house a couple of weeks ago. SOB! lol
I'm interested in some stuff.
Lol didn't know what I had at the time
