I guess the title is kinda self explanatory but I was wondering which would be better... I'm set on a strut/spring combo and I'm going with the most basic GR2s (they're cheap and if they get the job done whatever) ... So I read up Eibachs = more handling focus with bad ride, Vogtlands tho are kinda vague, most of the comments I read about Vogtlands are comfortable but not much is said about the handling. I also read on this forum Vogtland's spring rates are very similar to the Eibach's. Vogtlands seem like the more ideal choice on the GR2s since they drop only about an inch or so but how much body roll are the Vogtlands gonna control? How about the grip levels between the 2 (I'd assume they'd be similar since they've got similar spring rates, same with the body roll). I'd rather not have the 34 mm front sway bar and stick with the stock 28 mm to have as much grip up front as possible and would prefer to control body roll with springs instead of the front sway bar, but I'd also rather not overwhelm the GR2s. Anyone have experience with these?
Edit: ik the Vogtlands came with the original GMPP w/ Koni kit so I'd kinda assume they'd be ideal all the way around (including handling), but unlike the original GMPP I'd like to keep the oe 28 mm front sway bar with maybe poly bushings and run a 22 mm rear addco bar so most of the grip lies up front and the rear is relatively easy to rotate.
