    TIPS:
Race Parts for sale
Oh yea I remember now the line fittings are different however just change the fittings to the new style and everything else is the same. I think I may have some of those new fittings as well. Whoever wants the trans will get the correct fittings for there car :)
SCRAPED Any Need Transmission Hard Parts
Otherwise I'm making a trip to the junk Yard :(
SOLD Also here's the pics of the NEW Short Block I have listed
SOLD Here are the C-YA Transmission pics:
It's been just sitting on the shelf for about three years now, It worked great in the last car I had it in. (Car rusted out in the rear shock towers with 245,000 miles on the original stock motor)
It had a pretty easy life for the last 20,000 miles or so :)
SOLD I will cross post this in Wheels and tires but I thought I should put it here as well.
Drag Race wheels and tires both front and rear made special for the GTP:
The rear wheels and tires:
weight = 22 lbs Ea. with tires
tires: Morso DS-2
tire size: 26x4.5x15
The front wheels and tires:
weight = 37 lbs with tires
tires:M/T ET-Streets
tire size: 26x11.5x15
Rear Pics:
Front Pics:
I will sell all 4 as a set only.
The fronts require a 1/2" thick spacer to clear the brakes. That's an available part I believe.
Thanks
There is a pending sale on these Parts:
CNC Heads Sold
Transmission Sold
New Short block Sold
Wheels and Tires Sold
I will be adding more parts as I find them as well so stay tuned you never can tell what I'll find upstairs in my shop.
ALL SOLD I found a couple 300M input shafts I would like to sell them to someone that needs them. I had several made way back even before intense had them. Actually Intense made there's after they saw mine at GPG. Anyway!
These are unused, I decided to not call anything new anymore because every thing has been in storage for so long :(
ALL SOLD Differential Pinion Shaft Made from hardened tool steel. A hole for a larger roll pin (3/16 x 1.5) so you will have to drill the existing roll pin hole in the diff 3/16 not hard to do at all.
There are 2 flats milled under each of the side gears to allow oil to get in and keep the side gears lubed. They have been coated with a coating called Micro Blue The Nascar racers use this on all the bearings and it saves them tons of failures. I have 35 of these available.
SOLD
Unused set of Valve Springs Compcams PN: 26918-16
