Brammer
use the rtv in the kit, get a extra qt or two of oil to wash down the lim should you spill coolant.
the valve cover kits get a felpro kit with grommets, rock auto once again is as cheap as you may find. local its a 75 dollar kit.
when you put the covers back on, take a look at the bolts, they have a shoulder at the end of the threads, only snug these bolts, or you will snap them.
if you do spill coolant you'll really want to dump the oil, then add your new oil and filter, run it for a few minutes, and change the oil and filter once more to make sure the coolant is out of the engine.
I've actually got a set of the FelPros that were intended for my GT, but never needed, they've been rolling around in the trunk of the GT for a good year now. So don't torque to spec, just snug and that's it?
