Brammer
I know there's a benefit to installing higher ratio rocker arms, springs and push rods whilst I'm in there, but that's a little out of the price range at the moment. Is there a benefit of replacing the lifters while I'm in there without doing the rockers, springs and rods?
Also out of curiosity, how do you replace the springs on the valves with the head in place? I replaced the valve springs and valves on my motorcycle, but I had the head off for that. How do you keep the valves from dropping into the motor? I've seen friends put the motor at TDC and feed rope in through the spark plug hole, granted that was a Miata however.
