DanPrixGTP
Moderator
I actually meant knock sensors... My bad
the gauge reads -* as in degrees before, is this correct? I've never used one of those. But if that is the way it reads then that is low timing for sure. Mine would go to 0 and 15*adtc. It's done 10* atdc but I have some other issue as well. Mine was doing just that before I changed the knock sensors but it even did it with that other computer so I think in my case it was both the PCM and knock sensor. Did it just all of a sudden happen or progressively over time? Did it happen right after a tune?
Jeff
I use the symbol * to represent Degrees. Knock Retard and Timing are both read in Degrees. Mine could be a combination of both, like you stated. Knock Sensors and a PCM issue. This all of sudden happened a few months ago, but I never really cared about it because Cruise Timing isn't "detrimental" to an engine like WOT KR is. But it has gotten worse over time, and now when I'm cruising anywhere, my KR is pegged at 14.9* KR and the car is pulling all my timing, and causing me to average 14 MPG. And this can't keep going on, as the issue needs to get fixed since I'm wasting my money on fuel every 4 days. Averaging $40 every 3-4 days.
I think there is something in the program's get (either stock or aftermarket) that causes it to do so without the knock sensors connected. Like a default table of sorts.
Edit: remember that I am guessing on this as I have no GM program experience.
Jeff
Your guess is as good as mine, at this point. Luckily, I do have a ZZP Canned tune for my car laying around in my garage. It's a **** tune as my LTFTs are -21 +/- while driving, but it might give me an idea if the KR is related to a bad PCM or not. I could try switching the PCM's and plugging my Knock Sensors back in, and seeing what it does.
I'll take a look at the tables in Tiny Tuner, but who knows if there is a hidden table that is causing this. There are definitely several tables that modify spark, but for your scanner to show KR I would think that could only come from one place-knock sensor. Its like having the MAF unplugged but still reading MAF frequency changes. Doesn't make sense to me.
Exactly. My only thought at this point is it's PCM related or possibly a combination of both a bad PCM in that regards and faulty Knock Sensor(s). Like I mentioned above ^ I do have a spare ZZP Canned Tune PCM in my garage I will switch out and see what the car does. Could also try putting my newer Denso o2 sensor back in as well.
