CapnBreakAlot
Master-Breaker
Got the modded rails, 42.5s, ported blower and phenolic spacer on today... Aaaaand have a big boost leak.. only making 7# on the 3.4.. looks like I'll have to tear it apart again before Friday.
I made 11# on the 3.4 with rockers, I made 9# with the cam before the 1/4" spacer, now I'm only seeing 7, I saw 8 once at the top of 2nd.the cam should lower your boost, not raise it.
Screeching under boost could be a sign of a pcv issue......when you take your oil cap off is there sucking?..maybe the spacer blocked pcv or messed it up..not fimailiar with spacer.You can hear it under load. Around 3-4# you can hear a screeching sound.
I wondered about that but there's a hole for the pcv there.. I'll have to look at it again.Screeching under boost could be a sign of a pcv issue......when you take your oil cap off is there sucking?..maybe the spacer blocked pcv or messed it up..not fimailiar with spacer.
Yep just the spacer, no IC yet.
It's a phenolic spacer, phenolic material has no heat transfering properties, so it helps with keeping the heat of the motor rising up and heat soaking the blower.Just treat me like a dumb blonde... What's the spacer for? Lol
Of course...Soooo being right above the exhaust in the enclosed engine bay doesn't transfer any heat once the spacer is in place...right?
