Re: Top Swap in progress, few questions
The Base_PE_AF table, yeah. Any time I change that, I change the whole table to the same value.
You are freakin awesome dude.
So, I got some really really really good news, that no one but me will probably care to know but oh well lol. I've been getting some misfires on cy3. So I thought, what the hell, car still has original coil packs on, might as well get some new ones to rule them out. ACDelco are only 22 bucks a piece, so cheap maintenance. Popped them on when I got home and went for a ride. Soon as I get on it it REALLY started acting up. Spittin and cussing, the car too, I took it back home. I had an extra set of wires..still waiting on a NEW set to come in from Amazon, so I put them on. Wait, back up...the misfire was happening on cy3, so I swapped 3 and 5 plugs wires and this misfire followed the bad wire. But I was also randomly getting misfire on other cylinders. THAT's when I put on the spare set of wires. Took it for a spin and..>>WOW!!! This is the FIRST time I've actually felt my car running like I thought it should be. It actually PULLED, OMG lol. And earlier I topped off with my second tank of E85, so the mixture is getting closer to pure corn. Result....NO knock, just a little blip every now and then, but none at WOT. Oh, and I put on the 3.25 pulley yesterday.
Sorry about the childish giddiness, but I finally feel I got paid for my hard work. I'm only at 13 degrees at WOT, so I think there is more power to be had. I did run a new tune where I stuck a the stock timing tables in from an 04 gtp. Thanks Scott for that tip. I'm sure that helped because all my noobish eagerness has probably mangled my timing tables trying to learn how to use Table Modifier. Happy vibes to all that have chimed in and helped. I finally have a stable platform that I can tweak. Got the new glasspack in the mail yesterday, so hope to have it on the car this weekend. All I want to hear is that blower whine
And I scored a new 04 1" radiator that I'm gonna try to install soon. Car seems to run warm since I reverse flushed the Dex out of it, probably plugged somewhere.
Now that I can get some good scans I'm gonna get the trims dialed in and then hit the track. Hope I'm at least out of the 17's lol. If not, cam might happen sooner than I planned.
Edit: for those who don't care to read my rant, bottom line: If your car has over 130k and you are still running stock coil packs, slap yourself and install some new ones.
