Re: Top Swap in progress, few questions
I think I broke something....already
lol
I am getting some odd noises from the front passenger side. It sounds a bit like a brake dragging when I'm going slow. And it has felt like the brake was on when I put it in reverse, with some grinding sounds. But it doesn't do it all the time, the squeak it does, but the dragging sound/feel in reverse has only happened a couple times. I attributed this to my brakes. Have had several issues in the past, had to replace the emergency brake lines because they would stick so thats kinda what I thought it was again, or I colapsed a brake line because I had to bend the front passenger line a little when working on headers. It actually made the grinding sound and dragged the first time I backed out of the garage after taking it off the jack stands so I don't think I did it while driving it. I had the e-brake on for a few days so I just assumed it was sticking again.
I jacked up the front and when I spin the tire I hear the squeak coming where the shaft goes in the tranny. It sounds like wet rubber on rubber. And feels kinda sloppy when I move rotate it back and forth, though I know some slop is usually normal. Any clues? I'm thinking the cv axle shaft is shot, but I really don't know much about transmissions. Could it be deeper, worse?
But there is good news too. Reptile came through for me with a revamped tune. He tweaked the MAF table more, and it is running WAY better. Fuel trims are a lot better when cruising, just crappy when decel and idling. But we're on the right path for sure. And I wasn't seeing boost past 4lbs. So I pulled the hose off the selenoid and now I'm hitting between 7-8lbs. No idea why the selenoid is pulling out boost. Anyways +rep to Reptile for blindly getting me to a drivable state
I've only gone about 60% throttle because I'm getting some KR, but the shifts are really amazing. He has really woke it up, but I may have to tame it a bit because I'm afraid of tearing the tranny up. I do want to put a better built tranny in, but want to enjoy the car for awhile first.
Sheesh, long boring post, sorry.
Notes:
1. Something broke
2. Reptile is awesome
