Re: 1997 Black GTP, Car is Officially Lowered.
Been working on the Front Air Dam a lot lately. Spring is finally here, or so it looks like. In that case, putting the new wheels/front air dam are going on within the next 2 weeks most likely, for good.
Bought an Air Sander and have sanded the million layers of clear/paint/primer off the Air Dam. Started with 50 grit, then 120, 220, 600, and 1000. After multiple hours of sanding, 99% of everything is removed and ready for primer after I wash it.
I also bought an actual spray gun. Hopefully this will make a nice difference, we'll find out.
Should be completed by early next week, is my guess.
Also, the car was on the struggle bus the past few days. Did a WOT pull a few days ago, then found my engine smoking. "Luckily" it was just coolant that sprayed all over the engine. Ended up being a crack in a heater hose. Made a junkyard run and got another, fixed that issue.
Day after, leaving the car wash, car's shift schedule was completely messed up. TPS went bad, randomly. $40 later, replaced the sensor and shes back to new again.
Did another WOT pull on the highway yesterday and saw 8* KR. Most I've ever seen since stock. Tried another WOT pull today and 0 KR. Odd, maybe the ol' 97 was just being grumpy yesterday. I'll probably pull and replace the plugs this weekend just to check them out.
Cool stories, huh?
