    TIPS:
Wtb l32 top swap parts
I might have the extra pulley arm, the l67 crank pulley , maybe the heads too, new timing chain - gears - dampner ... There's stuff floating around. Just gotta see where it all is sorted and boxed away at
I should have pretty much everything (no throttle body, and coil bracket doesn't have coils/icm).
I'd suggest having the heads gone through as I got them with a light coat of surface rust in a box in the trunk of my 04 Comp G when I bought it -the car hasn't been on the road in ~1 year.
Might be missing a few nuts/bolts, but whatever nuts/bolts I have for the conversion I will include.
$450 shipped in lower 48 states.
Can you get me a list of everything big That you don't have and I would be interested in buying this. I just need to see how many hours I work this next week in order to give you a time line
I know I have the Gen V, matching LIM, the longer Gen V SC bolts, L32 fuel rails with injectors, 'stand off pulley/bracket' for SC belt, harmonic balancer, L32 heads, L67/L32 coil bracket with sc belt tensioner, and I believe I have a rear valve cover but will have to dig around for a front valve cover.
Pmed
